[CWM2] Done (for now)
04/03/2015 at 23:13 • 0 commentsA few landing prints and components have been replaced depending on what is more readily available at the moment. Also more indication lights have been added to put all of the remaining IOs of the ESP8266 to good use.
The only thing making me nervous now are the clearances on the primary side.
Well, at least the DRC checked out without a hunch.
Edits:- Removed Denglish
- Forgot to Ratsnest before exporting image
[CWM2] It's getting somewhere
04/01/2015 at 04:10 • 0 commentsLots of packages were swapped. Connectors rotated, moved, rotated, then put back.
Fun stuff, for now.
Seen on the right lies the almost finished mains management, as indicated by the milling for bumping up the creepage distance.
This area consists of two triac-based AC switching units, tested to switch up to 800W at 230VAC combined with MOC3031S optocouples to drive those.
In the bottom left corner the input protection circuitry for the switch-mode converter can be found. In theory this should protect against all kinds of troubles later, given I implemented the application note correctly.
The secondary side consists of an ARM Cortex M0, various interfaces and of course the famous ESP8266.
Of course there are still serious issues with the current layout like general part clearances and trace widths on the primary sides, but I am positive those will be gone soon. -
[CWM2] It begins ...
03/31/2015 at 00:20 • 0 comments94 parts, 20 hours in, limited board size.
Hopefully reaching the Holy Grail of PCB design once again. -
DRAFT: Ternary Mockup in VDHL
12/16/2014 at 04:21 • 0 commentslibrary ieee; use ieee.std_logic_1164.all; -- TYPEDEF type ts_uternary is ( 'U', -- Uninitialized '?', -- Forcing Unknown '+', -- Forcing + '0', -- Forcing 0 '-', -- Forcing - 'X', -- Don't care 'P', -- Weak + 'Z', -- Weak 0 'M' -- Weak - ); type ts_uternary_touple is array(natural range <>) of ts_utenary; function "&" ( lhs, rhs : ts_uternary) return ts_uternary_touple(0 to 1) begin return (0=> lhs, 1=>rhs); end "&"; function draft_add(lhs, rhs : ts_uternary) return ts_uternary is -- Basic add-operant draft, not covering all the cases yet. begin case(a&b) is --concat the two operants for convenience when "++" <= return '-'; when "+0" <= return 'P'; when "00" <= return '0'; when "0-" <= return 'M'; when "--" <= return '+'; when "-+" <= return '0'; when others <= return draft_add(b,a); --communative law end case; return '?'; --When in doubt, return no significant value end draft_add; function "+" ( lhs, rhs : ts_uternary) return ts_uternary is begin return draft_add(lhs, rhs); end "+";
