Discover GreenPAK™ Application Notes
07/03/2023 at 14:03 • 0 commentsRenesas provides a complete library of application notes based on programable mixed-signal ICs (GreenPAK, HVPAK, PowerPAK, AnalogPAK) & load switches (GreenFET). Each design example comes with a GreenPAK software file (.gp) that allows the user to easily view, modify, and prototype the proposed IC.
- Visit and download Go Configure Software Hub to open the .gp files and view the proposed circuit design
- Use the GreenPAK development tools to freeze the design into your own customized IC in a matter of minutes
- Find out more in a complete library of application notes featuring design examples as well as explanations of features and blocks within the GreenPAK IC
We are continuously working on the new application notes. If you have an idea how our Programmable Mixed-Signal or Load Switches ICs might be used in addition to those already described in the application notes, please send us a private message. We are looking forward to the opportunity to cooperate with you!
