Ultrasonic Lighting
10/09/2020 at 02:22 • 0 commentsThis article shows an ultrasonic sensor lighting system:
You can see my circuit working in this video:
I created this circuit after reading those articles:
https://www.instructables.com/Ultrasonic-Alien
https://www.instructables.com/Sound-Light-Robot
Step 1: Design the Circuit
I have drawn the circuit in the old PSpice simulation software (student edition version 9.1) to reduce drawing and simulation time.
The Rv potentiometer controls the brightness of the bright LED. The LEDs I used in my circuit might need a current of 20 mA. A typical LED consumes a current of 10 mA and has a potential voltage of 2 V across its terminals. High currents might burn the LED or reduce the LED's lifetime.
Although microphone circuits are always biased, most ultrasonic circuits do not bias the ultrasonic sensor. In my circuit, the DC current across the sensor is very small.
The Ri1 resistor is needed because the potential voltage across the ultrasonic sensor could be minimal (below 0.7 V) due to low resistance/impedance.
The LED will turn ON and OFF when the ultrasonic signal is applied.
Step 2: Simulations
Simulations show that my design is correct:
Time Domain Simulations:
Frequency Spectrum:
Step 3: Make the Circuit
You do not need to use the high-power resistors that I used. I used 1-watt resistors. You can use 1/4-watt resistors. However, you must admit that the circuit appears more professional with bigger resistors.
Second photo:
Step 4: Testing
I connected the ultrasonic transducer to Dick Smith Electronics FG-30 3 MHz Function Generator.
I adjusted the signal for maximum resonance and recorded the input signal applied to the ultrasonic transducer. I used a Hantek 6022BE USB Oscilloscope:
The measured frequency was 40.8 kHz and the peak-to-peak voltage was 9.6 V.
Testing showed that the circuit is receiving reflected and direct signals.
Conclusion
The circuit presented in this article is an ultrasonic detector. This circuit is not the best method of detecting ultrasonic signals. A better way would be to implement AC amplifiers rather than DC amplifiers. This way would can significantly increase the receiving range of the circuit (maximum distance from the transmitter to the receiver for detection).
Potatoes and Eggs
08/20/2020 at 12:13 • 0 commentsI made a dish from:
- baked potatoes,
- baked onions,
- and boiled eggs.
You can see the photo here:
Tastes great!
Seashell Eggs
03/03/2020 at 09:29 • 0 commentsThis project needs very little work:
You need:
- seashell,
- 15 small pom poms (not all are seen in this photo),
- PVA glue, blue tack or sticky tape.
Step 1: Clean the seashell
Step 2: Pour PVA glue inside the seashell
You can see that I poured very little glue inside the shell). You can also try other sticky materials that I mentioned above.
Step 3: Put pom poms on top of glue
Try not to force the pom poms inside the glue. Otherwise the glue will come out of the seashell.
Step 4: Leave to dry for 24 hours
