Difference between Lithium-Ion & LifeP04 Battery
05/29/2020 at 12:32 • 0 commentsHi ! Are you curious to know what makes Lithium-Ion & LifeP04 batteries different from each other apart from their names? Here is the required information. But, first let me introduce you with both of the batteries to make you a little bit more familiar to them.
Read more -
Introduction to Lithium Ion Battery
05/20/2020 at 12:38 • 0 commentsA lithium-ion battery or Li-ion battery (abbreviated as LIB) is a type of rechargeable battery. It is a lightweight, high-power battery used in computers and mobile phone. You might have seen the batteries inside nokia cell phones’ had mentioned li-ion on them. These are lithium ion batteries. Li-ion batteries come in several shapes, although a flat rectangle is most common.
Read more -
Drone Parts & Components' Overview
05/18/2020 at 10:16 • 0 commentsNowadays, Unmanned Aerial Vehicles (UAVs) are becoming popular with their high flying capacities, image capturing & video recording features, and most importantly, their parts & components which play a vital role in this small yet powerful Unmanned Aircraft System (UAS), which you normally call as “Drone”!
It's very important for a drone beginner to know the anatomy of this aircraft system. So, in this article, we are going to discuss various parts & components of a drone w.r.t. an illustrated image given below.
Read more -
Detailed Guide for Choosing LiPo Battery for Your Drone
05/16/2020 at 06:41 • 1 commentA battery is energy source for your Unmanned Aircraft System (UAS) i.e. your drone. This battery should be good enough to help a drove fly for longer time, that’s what every pilot wants, isn’t it? The flight time i.e. the time spent by drone in the sky is dependent on the batteries. So, selection of drone batteries is the wisest choice one has to make.
Lithium Polymer or LiPo batteries have a lot of benefits such as light weight, high capacities, high discharge rates, etc. that have made them the best choice in consumer drones. They have a high energy density in relation to their size and weight, with a higher voltage per cell, typically 3.7 volts, so you can get the necessary power with fewer cells than other rechargeable batteries. However, the LiPo batteries have shorter lifespan and they can lead to fire if the battery gets punctured. So, they are very sensitive and need special care for charging, discharging, and storage.
There are so many features, specifications, and price tags for various kinds of LiPo batteries available in the market, but it’s always important to keep your budget balanced with the quality of batteries you’re going to buy. However, it’s not too wise to save money for some cheaper quality of batteries and risk your expensive drone into higher repair or replacement charges.
So, this article is mainly focused in terms of a drone user’s perspective with some guidelines and explanations about how to select LiPo battery for your drone.
Read more
