Ultra Simple Character Driver
A project log for SAGES
What is the best way to ensure the progress of humanity 10,000 years in the future?
jareklupinskijareklupinski 05/29/2016 at 19:190 Comments
After trying to write my own 8x8 font, I gave up and grabbed https://github.com/dhepper/font8x8 . Had to grab a byte reversing routine from the Arduino forums to make it work with my buffer.
#define D0_PIN 0  //SPI Clock
#define D1_PIN 1  //SPI Data
#define CS_PIN 2  //Chip Select, Low to select chip
#define DC_PIN 3  //When Sending Index set to Low, When sending Data set to High
#define RS_PIN 4  //Reset pin, hold High
#define BS_PIN 5  //Busy Pin, Low is busy
#define VC_PIN 6  //Power pin to display, make sure chip can source 10mA or use a mosfet switch
static byte screen[2912];
char font8x8_basic[128][8] = {
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0000 (nul)
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0001
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0002
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0003
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0004
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0005
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0006
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0007
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0008
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0009
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+000A
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+000B
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+000C
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+000D
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+000E
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+000F
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0010
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0011
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0012
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0013
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0014
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0015
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0016
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0017
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0018
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0019
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+001A
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+001B
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+001C
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+001D
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+001E
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+001F
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0020 (space)
  { 0x18, 0x3C, 0x3C, 0x18, 0x18, 0x00, 0x18, 0x00},   // U+0021 (!)
  { 0x36, 0x36, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0022 (")
  { 0x36, 0x36, 0x7F, 0x36, 0x7F, 0x36, 0x36, 0x00},   // U+0023 (#)
  { 0x0C, 0x3E, 0x03, 0x1E, 0x30, 0x1F, 0x0C, 0x00},   // U+0024 ($)
  { 0x00, 0x63, 0x33, 0x18, 0x0C, 0x66, 0x63, 0x00},   // U+0025 (%)
  { 0x1C, 0x36, 0x1C, 0x6E, 0x3B, 0x33, 0x6E, 0x00},   // U+0026 (&)
  { 0x06, 0x06, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0027 (')
  { 0x18, 0x0C, 0x06, 0x06, 0x06, 0x0C, 0x18, 0x00},   // U+0028 (()
  { 0x06, 0x0C, 0x18, 0x18, 0x18, 0x0C, 0x06, 0x00},   // U+0029 ())
  { 0x00, 0x66, 0x3C, 0xFF, 0x3C, 0x66, 0x00, 0x00},   // U+002A (*)
  { 0x00, 0x0C, 0x0C, 0x3F, 0x0C, 0x0C, 0x00, 0x00},   // U+002B (+)
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x0C, 0x06},   // U+002C (,)
  { 0x00, 0x00, 0x00, 0x3F, 0x00, 0x00, 0x00, 0x00},   // U+002D (-)
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x0C, 0x00},   // U+002E (.)
  { 0x60, 0x30, 0x18, 0x0C, 0x06, 0x03, 0x01, 0x00},   // U+002F (/)
  { 0x3E, 0x63, 0x73, 0x7B, 0x6F, 0x67, 0x3E, 0x00},   // U+0030 (0)
  { 0x0C, 0x0E, 0x0C, 0x0C, 0x0C, 0x0C, 0x3F, 0x00},   // U+0031 (1)
  { 0x1E, 0x33, 0x30, 0x1C, 0x06, 0x33, 0x3F, 0x00},   // U+0032 (2)
  { 0x1E, 0x33, 0x30, 0x1C, 0x30, 0x33, 0x1E, 0x00},   // U+0033 (3)
  { 0x38, 0x3C, 0x36, 0x33, 0x7F, 0x30, 0x78, 0x00},   // U+0034 (4)
  { 0x3F, 0x03, 0x1F, 0x30, 0x30, 0x33, 0x1E, 0x00},   // U+0035 (5)
  { 0x1C, 0x06, 0x03, 0x1F, 0x33, 0x33, 0x1E, 0x00},   // U+0036 (6)
  { 0x3F, 0x33, 0x30, 0x18, 0x0C, 0x0C, 0x0C, 0x00},   // U+0037 (7)
  { 0x1E, 0x33, 0x33, 0x1E, 0x33, 0x33, 0x1E, 0x00},   // U+0038 (8)
  { 0x1E, 0x33, 0x33, 0x3E, 0x30, 0x18, 0x0E, 0x00},   // U+0039 (9)
  { 0x00, 0x0C, 0x0C, 0x00, 0x00, 0x0C, 0x0C, 0x00},   // U+003A (:)
  { 0x00, 0x0C, 0x0C, 0x00, 0x00, 0x0C, 0x0C, 0x06},   // U+003B (//)
  { 0x18, 0x0C, 0x06, 0x03, 0x06, 0x0C, 0x18, 0x00},   // U+003C (<)
  { 0x00, 0x00, 0x3F, 0x00, 0x00, 0x3F, 0x00, 0x00},   // U+003D (=)
  { 0x06, 0x0C, 0x18, 0x30, 0x18, 0x0C, 0x06, 0x00},   // U+003E (>)
  { 0x1E, 0x33, 0x30, 0x18, 0x0C, 0x00, 0x0C, 0x00},   // U+003F (?)
  { 0x3E, 0x63, 0x7B, 0x7B, 0x7B, 0x03, 0x1E, 0x00},   // U+0040 (@)
  { 0x0C, 0x1E, 0x33, 0x33, 0x3F, 0x33, 0x33, 0x00},   // U+0041 (A)
  { 0x3F, 0x66, 0x66, 0x3E, 0x66, 0x66, 0x3F, 0x00},   // U+0042 (B)
  { 0x3C, 0x66, 0x03, 0x03, 0x03, 0x66, 0x3C, 0x00},   // U+0043 (C)
  { 0x1F, 0x36, 0x66, 0x66, 0x66, 0x36, 0x1F, 0x00},   // U+0044 (D)
  { 0x7F, 0x46, 0x16, 0x1E, 0x16, 0x46, 0x7F, 0x00},   // U+0045 (E)
  { 0x7F, 0x46, 0x16, 0x1E, 0x16, 0x06, 0x0F, 0x00},   // U+0046 (F)
  { 0x3C, 0x66, 0x03, 0x03, 0x73, 0x66, 0x7C, 0x00},   // U+0047 (G)
  { 0x33, 0x33, 0x33, 0x3F, 0x33, 0x33, 0x33, 0x00},   // U+0048 (H)
  { 0x1E, 0x0C, 0x0C, 0x0C, 0x0C, 0x0C, 0x1E, 0x00},   // U+0049 (I)
  { 0x78, 0x30, 0x30, 0x30, 0x33, 0x33, 0x1E, 0x00},   // U+004A (J)
  { 0x67, 0x66, 0x36, 0x1E, 0x36, 0x66, 0x67, 0x00},   // U+004B (K)
  { 0x0F, 0x06, 0x06, 0x06, 0x46, 0x66, 0x7F, 0x00},   // U+004C (L)
  { 0x63, 0x77, 0x7F, 0x7F, 0x6B, 0x63, 0x63, 0x00},   // U+004D (M)
  { 0x63, 0x67, 0x6F, 0x7B, 0x73, 0x63, 0x63, 0x00},   // U+004E (N)
  { 0x1C, 0x36, 0x63, 0x63, 0x63, 0x36, 0x1C, 0x00},   // U+004F (O)
  { 0x3F, 0x66, 0x66, 0x3E, 0x06, 0x06, 0x0F, 0x00},   // U+0050 (P)
  { 0x1E, 0x33, 0x33, 0x33, 0x3B, 0x1E, 0x38, 0x00},   // U+0051 (Q)
  { 0x3F, 0x66, 0x66, 0x3E, 0x36, 0x66, 0x67, 0x00},   // U+0052 (R)
  { 0x1E, 0x33, 0x07, 0x0E, 0x38, 0x33, 0x1E, 0x00},   // U+0053 (S)
  { 0x3F, 0x2D, 0x0C, 0x0C, 0x0C, 0x0C, 0x1E, 0x00},   // U+0054 (T)
  { 0x33, 0x33, 0x33, 0x33, 0x33, 0x33, 0x3F, 0x00},   // U+0055 (U)
  { 0x33, 0x33, 0x33, 0x33, 0x33, 0x1E, 0x0C, 0x00},   // U+0056 (V)
  { 0x63, 0x63, 0x63, 0x6B, 0x7F, 0x77, 0x63, 0x00},   // U+0057 (W)
  { 0x63, 0x63, 0x36, 0x1C, 0x1C, 0x36, 0x63, 0x00},   // U+0058 (X)
  { 0x33, 0x33, 0x33, 0x1E, 0x0C, 0x0C, 0x1E, 0x00},   // U+0059 (Y)
  { 0x7F, 0x63, 0x31, 0x18, 0x4C, 0x66, 0x7F, 0x00},   // U+005A (Z)
  { 0x1E, 0x06, 0x06, 0x06, 0x06, 0x06, 0x1E, 0x00},   // U+005B ([)
  { 0x03, 0x06, 0x0C, 0x18, 0x30, 0x60, 0x40, 0x00},   // U+005C (\)
  { 0x1E, 0x18, 0x18, 0x18, 0x18, 0x18, 0x1E, 0x00},   // U+005D (])
  { 0x08, 0x1C, 0x36, 0x63, 0x00, 0x00, 0x00, 0x00},   // U+005E (^)
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF},   // U+005F (_)
  { 0x0C, 0x0C, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+0060 (`)
  { 0x00, 0x00, 0x1E, 0x30, 0x3E, 0x33, 0x6E, 0x00},   // U+0061 (a)
  { 0x07, 0x06, 0x06, 0x3E, 0x66, 0x66, 0x3B, 0x00},   // U+0062 (b)
  { 0x00, 0x00, 0x1E, 0x33, 0x03, 0x33, 0x1E, 0x00},   // U+0063 (c)
  { 0x38, 0x30, 0x30, 0x3e, 0x33, 0x33, 0x6E, 0x00},   // U+0064 (d)
  { 0x00, 0x00, 0x1E, 0x33, 0x3f, 0x03, 0x1E, 0x00},   // U+0065 (e)
  { 0x1C, 0x36, 0x06, 0x0f, 0x06, 0x06, 0x0F, 0x00},   // U+0066 (f)
  { 0x00, 0x00, 0x6E, 0x33, 0x33, 0x3E, 0x30, 0x1F},   // U+0067 (g)
  { 0x07, 0x06, 0x36, 0x6E, 0x66, 0x66, 0x67, 0x00},   // U+0068 (h)
  { 0x0C, 0x00, 0x0E, 0x0C, 0x0C, 0x0C, 0x1E, 0x00},   // U+0069 (i)
  { 0x30, 0x00, 0x30, 0x30, 0x30, 0x33, 0x33, 0x1E},   // U+006A (j)
  { 0x07, 0x06, 0x66, 0x36, 0x1E, 0x36, 0x67, 0x00},   // U+006B (k)
  { 0x0E, 0x0C, 0x0C, 0x0C, 0x0C, 0x0C, 0x1E, 0x00},   // U+006C (l)
  { 0x00, 0x00, 0x33, 0x7F, 0x7F, 0x6B, 0x63, 0x00},   // U+006D (m)
  { 0x00, 0x00, 0x1F, 0x33, 0x33, 0x33, 0x33, 0x00},   // U+006E (n)
  { 0x00, 0x00, 0x1E, 0x33, 0x33, 0x33, 0x1E, 0x00},   // U+006F (o)
  { 0x00, 0x00, 0x3B, 0x66, 0x66, 0x3E, 0x06, 0x0F},   // U+0070 (p)
  { 0x00, 0x00, 0x6E, 0x33, 0x33, 0x3E, 0x30, 0x78},   // U+0071 (q)
  { 0x00, 0x00, 0x3B, 0x6E, 0x66, 0x06, 0x0F, 0x00},   // U+0072 (r)
  { 0x00, 0x00, 0x3E, 0x03, 0x1E, 0x30, 0x1F, 0x00},   // U+0073 (s)
  { 0x08, 0x0C, 0x3E, 0x0C, 0x0C, 0x2C, 0x18, 0x00},   // U+0074 (t)
  { 0x00, 0x00, 0x33, 0x33, 0x33, 0x33, 0x6E, 0x00},   // U+0075 (u)
  { 0x00, 0x00, 0x33, 0x33, 0x33, 0x1E, 0x0C, 0x00},   // U+0076 (v)
  { 0x00, 0x00, 0x63, 0x6B, 0x7F, 0x7F, 0x36, 0x00},   // U+0077 (w)
  { 0x00, 0x00, 0x63, 0x36, 0x1C, 0x36, 0x63, 0x00},   // U+0078 (x)
  { 0x00, 0x00, 0x33, 0x33, 0x33, 0x3E, 0x30, 0x1F},   // U+0079 (y)
  { 0x00, 0x00, 0x3F, 0x19, 0x0C, 0x26, 0x3F, 0x00},   // U+007A (z)
  { 0x38, 0x0C, 0x0C, 0x07, 0x0C, 0x0C, 0x38, 0x00},   // U+007B ({)
  { 0x18, 0x18, 0x18, 0x00, 0x18, 0x18, 0x18, 0x00},   // U+007C (|)
  { 0x07, 0x0C, 0x0C, 0x38, 0x0C, 0x0C, 0x07, 0x00},   // U+007D (})
  { 0x6E, 0x3B, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // U+007E (~)
  { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}    // U+007F
void softwareSpi( byte data ) {
  for ( int i = 0; i < 8; i++ ) {
    if ((( data >> (7 - i) ) & 0x01 ) == 1 ) digitalWrite( D1_PIN, HIGH );
    else digitalWrite( D1_PIN, LOW );
    digitalWrite( D0_PIN, HIGH );
    digitalWrite( D0_PIN, LOW );
void sendIndexData( byte index, byte *data, int len ) {
  digitalWrite( CS_PIN, LOW );
  digitalWrite( DC_PIN, LOW );
  softwareSpi( index );
  digitalWrite( DC_PIN, HIGH );
  for ( int i = 0; i < len; i++ ) softwareSpi( data[ i ] );
  digitalWrite( CS_PIN, HIGH );
void driveCog() {
  //set pins to initial states
  digitalWrite( RS_PIN, LOW );
  //Power on COG
  digitalWrite( VC_PIN, HIGH );        //VCC High
  delay( 50 );                         //Delay 50ms
  digitalWrite( RS_PIN, HIGH );        //RES# = 1
  delay( 1 );                          //Delay 1ms
  digitalWrite( CS_PIN, HIGH );        //CS# = 1
  //Initialize COG Driver
  while ( digitalRead( BS_PIN ) == HIGH ); //Make sure BUSY = LOW
  byte data1[] = { 0xCF, 0x00 };
  sendIndexData( 0x01, data1, 2 );     //Driver output control setting
  byte data2[] = { 0x00 };
  sendIndexData( 0x0F, data2, 1 );     //Gate scan start setting
  byte data3[] = { 0x03 };
  sendIndexData( 0x11, data3, 1 );     //Data entry mode setting
  byte data4[] = { 0x00, 0x0D };
  sendIndexData( 0x44, data4, 2 );     //Set RAM X - Start-End position
  byte data5[] = { 0x00, 0xCF };
  sendIndexData( 0x45, data5, 2 );     //Set RAM Y - Start-End position
  byte data6[] = { 0x00 };
  sendIndexData( 0x4E, data6, 1 );     //Set RAM X address counter
  byte data7[] = { 0x00 };
  sendIndexData( 0x4F, data7, 1 );     //Set RAM Y address counter
  //Send Image Data
  sendIndexData( 0x24, screen, 2912 );
  //Update command sequence
  byte data9[] = { 0x80 };
  sendIndexData( 0x3C, data9, 1 );     //Select border waveform
  byte data10[] = { 0x10, 0x0A };
  sendIndexData( 0x03, data10, 2 );    //Set gate driving voltage
  byte data11[] = { 0x00 };
  sendIndexData( 0x05, data11, 1 );    //Normal analog mode
  byte data12[] = { 0x00, 0x00, 0x00 };
  sendIndexData( 0x75, data12, 3 );    //Normal analog mode
  byte data13[] = { 0x19, 0x00 };
  sendIndexData( 0x1A, data13, 2 );    //Send the temperature value
  byte data14[] = { 0xF7 };
  sendIndexData( 0x22, data14, 1 );    //Set update sequence
  byte data15[] = { 0x00 };
  sendIndexData( 0x20, data15, 1 );    //Active display update sequence
  //Power Down COG driver after processing complete
  digitalWrite( VC_PIN, LOW );
  //Pull other pins low to prevent parasitic power consumption
unsigned char bitReverse( unsigned char x )
  x = ((x >> 1) & 0x55) | ((x << 1) & 0xaa);
  x = ((x >> 2) & 0x33) | ((x << 2) & 0xcc);
  x = ((x >> 4) & 0x0f) | ((x << 4) & 0xf0);
  return x;
void placeCharAt( char c, int x, int y ) {
    screen[ x + ( y * 14 * 8 ) + ( i * 14 )] = bitReverse( font8x8_basic[ c ][ i ] );
void setup() {
  //set I/O registers for pin functions
  pinMode( D0_PIN, OUTPUT );
  pinMode( D1_PIN, OUTPUT );
  pinMode( CS_PIN, OUTPUT );
  pinMode( DC_PIN, OUTPUT );
  pinMode( RS_PIN, OUTPUT );
  pinMode( VC_PIN, OUTPUT );
  pinMode( BS_PIN, INPUT_PULLUP );
  //Clear Screen Buffer
  for ( int i = 0; i < 2912; i++ ) screen[i] = 0x00;
  driveCog();
  //Test current fontmap
  for ( int i = 0; i < 128; i++ ) placeCharAt( i, i % 14 , i / 14 );
  driveCog();
void loop() {
