SSR Module Demo 2
A project log for Relay Hub
Build and use an array of Solid State Relays!
HexabitzHexabitz 03/29/2018 at 04:590 Comments
In this example:
How to execute this example?
The source code for this project is in the attached zip folder. Each demo example code is available in a separate C source file in User folder called main_ex1.cmain_ex2.c, etc. To run a specific example, replace the main.c file content with the content of the example file and recompile the project for all three targets. Check firmware update article for instructions on loading firmware to the modules.
