On IEEE-1355 vs UARTs
A project log for Kestrel Computer Project
The Kestrel project is all about freedom of computing and the freedom of learning using a completely open hardware and software design.
samuel-a-falvo-iiSamuel A. Falvo II 03/01/2017 at 18:130 Comments
I think I know why IEEE-1355 didn't take off. While cores for this interconnect are quite small (truly, about on par with EIA-232 UARTs with similarly sized FIFOs), they're not necessarily as easy to test as EIA-232. EIA-232 links are just about as simple as SPI, when push comes to shove: you have a dumb transmitter that isochronously sends out bits. It doesn't care what those bits are. You have a dumb receiver that plesiochronously attempts to sample bits. As long as the transmitting and receiving clocks are relatively synchronous with each other (the error is small enough), everything works and you get a reliable serial communications stream. The receiver's higher layers ultimately are responsible for packet framing. These two components, the receiver and transmitter, are otherwise 100% isolated from each other. That makes them easier to both validate and verify.
IEEE-1355 has separate TX and RX pipelines just like EIA-232; but, they're cross-coupled, and that means they interact. A feedback loop implicitly exists, which makes validation and verification a much more complicated affair. Transmitter A has a credit counter which is replenished by receiver B, while transmitter B's credit counter is replenished by receiver A. It does this through (preferably) hardware-scheduled transmission of FCT tokens.
Part of me wonders if I should have just stuck with an E1, ATM, or SONET-inspired frame structure, relying on scrambling to help ensure synchronization between TX and RX components. It sure seems like it would produce simpler hardware, be easier to test, and be easier to document as well. The problem remains of how to maintain synchrony between the transmitter and receiver after negotiating a higher throughput. Even at relatively modest speeds, the FT-232 chip on my Arduino Uno loses framing with my (then) host PC's serial port, apparently due to differing baud rate base frequencies.
