External Interrupt Supported
A project log for Kestrel Computer Project
The Kestrel project is all about freedom of computing and the freedom of learning using a completely open hardware and software design.
samuel-a-falvo-iiSamuel A. Falvo II 11/05/2016 at 07:060 Comments
The KCP53000 Verilog code now supports an external interrupt input. Interrupts have priority over other kinds of traps; because the MEPC register always points to the instruction that faults (or that would have faulted), an MRET instruction returns to that instruction and, presumably, would fault again for the same reasons. Thus, faults are never lost.
