MyLA: Debugging Tool for PSRAM (I Hope).
A project log for Kestrel Computer Project
The Kestrel project is all about freedom of computing and the freedom of learning using a completely open hardware and software design.
samuel-a-falvo-iiSamuel A. Falvo II 01/12/2017 at 08:030 Comments
I've adapted the KIA core for a new role as a logic analyzer data acquisition core, now called MyLA. I just pushed the core up to GitHub. It's not part of the Kestrel suite of cores, but maybe it should be. We'll see. For now, I'm hosting it under my personal account.
The plan is this:
  1. Take PSRAM off the primary CPU bus, and leave only block RAM. Relocate block RAM to $0000000000000000-$000000000000BFFF. This gives 48KB of system RAM to play with.
  2. Introduce a new core to expose PSRAM to the processor via Memory-Mapped I/O (MMIO). Once again, we can try async to start with, and maybe switch to sync later on. If going synchronous, then we need to ensure the clock is slow enough to afford MyLA some reasonable ability to sample the transaction. Maybe driving the PSRAM chip at 6.25MHz?
  3. Install the MyLA as another MMIO device, perhaps with some additional help from the GPIA as well. Configure MyLA to monitor the PSRAM controller's RAM-side interface.
  4. Implement enough firmware to interactively trigger PSRAM operations of various types (write BCR, read data from an address, write data to an address), as well as to arm/disarm the MyLA core.
  5. Implement enough firmware to visualize captured MyLA traces and to explore them.
This is going to take some time to complete. This weekend will be bad for me as I'll be at a fursuiting convention. Come Monday, I'll be back at it. Here's hoping I make good progress.
