Kestrel-1/3?
A project log for Kestrel Computer Project
The Kestrel project is all about freedom of computing and the freedom of learning using a completely open hardware and software design.
samuel-a-falvo-iiSamuel A. Falvo II 03/05/2017 at 06:120 Comments
Before I talk about what I'm doing now, let me talk about what I've done since my last update.
The Remex RX pipeline hasn't changed; it still receives characters and places them into a queue. I still have not yet designed a Wishbone interface for this queue yet. It's coming though.
The TX pipeline remains incomplete. I have the transmitting PHY/serializer, I have parity tracking, and I have the ability to transmit any N-Char or L-Char provided something spoon-feeds it. But, at the moment, I do not yet have a "what do I transmit next?" circuit that functions autonomously. It's designed, and I've written some Verilog for it, but it remains untested. I'm blocking on this, in part, because I'm not sure this is the direction I want to go. There's something nibbling at my gut that says the circuit I've designed is too complex and can be greatly simplified somehow. So, I'm meditating on it before I proceed further. If worse comes to worse, I can hook what I have up to a Wishbone interface, and let the CPU decide what to transmit and when. This will completely break compatibility with Spacewire and IEEE-1355, basically turning the interface into an RS-232 interface with data-strobe signalling. Not what I'd like to do if I can avoid it.
Per my previous post, since the RX and TX pipelines are cross-coupled with each other, and interactions exist both locally and remotely, you can imagine that testing this arrangement is on the more difficult side. Part of me is thinking that this is why IEEE-1355 interfaces have failed in commercial industry. EIA-232, T1, E1, SONET, and several ATM-based interfaces are based on a strictly unidirectional, synchronous or plesiochronous relationship between the bits sent by a transmitter and the bits received by another receiver. No feedback loops exist (at least at the physical and data-link layers), and therefore, are much simpler to test and predictably build hardware for. Because they were designed for time-division multiplexing, frame rates are (more or less) isochronous, and so buffer management is (ostensibly) simpler, since the need for deep buffers doesn't exist as long as you can service the bit-stream fast enough. This is now more appealing to me; however, the only thing stopping me from dropping IEEE-1355 and going back to telco-style, TDM-based protocols is, frankly, not knowing how to solve the auto-baud problem. So, IEEE-1355 it is for now.
So, what am I up to now? Honestly, trying for a small victory. My goal is, in essence, to reproduce the Kestrel-1 in the icoBoard that I've received. My plan is to embed a KCP53000 CPU and all the necessary bridging to a 16-bit Wishbone bus, couple it to the on-board SRAM chip, a 256 byte bootstrap ROM, and one GPIA core to provide general purpose I/O. The goal is to blink some LEDs under CPU control. That's it.
Unfortunately, I have no idea what the CPU core's timing is like, since the icotime utility reports a timing loop somewhere. Since this isn't necessarily a problem in practice, I'm planning on starting the CPU off at 1MHz, and ramping the clock up from there using a binary search to quickly determine, empirically, its maximum clock speed. I figure, at 1MHz, it will run at around 100,000 instructions per second, and should be plenty slow enough for the core to boot up. I doubt I'll be able to get the core running at 25MHz like on the Xilinx FPGA, but we'll see how well it fares. If it fares at all.
I'm hoping this works, for if I can't get something this simple working in a reasonable amount of time with a reasonable amount of effort, I see no further reason to continue to work on this project.
