Rework
A project log for ESP8266 websocket
ESP8266 websocket html5
willem-woutersWillem Wouters 03/08/2016 at 22:010 Comments
I did a lot of rework in separating the websocket parsing from the http server.
I you want to give the code a try,
Add your own ssid details in user_main.c
Change in index.html the websocket adres of the ESP
At the moment retreived by flashing the esp, check output for ip
Reflash esp with new firmware
make html
make
sudo make flash (check settings.mk for correct port)
Go to http://ipesp:8000
And I enabled some port forwarding, so for a online try:
http://willemwouters.nl:8000/
I put the esp in a box, so by turning on the led you will see the change in light intensity
Dont know how long it will stay online
