I entered the hackaday prize + bonus sneak preview
A project log for RpiFPV
Wifi or 4g FPV with the Raspberry pi and the camera board
richardginusrichardginus 08/05/2014 at 16:170 Comments
I finally had the guts to enter this project into the hackaday prize. I didn't do it before because i cant work on the project until the 18th of August. We'll see if i make the first cut!
Here is a preview of my current results:
It is an image of the camera filming the screen of the viewer. The end to end latency is calculated by subtracting the right number from the left number.
3.89 - 3.73 is 0.16 seconds. That is only 160 milliseconds!
This test was conducted at point blank WiFi range. The raspberry and the laptop are both connected via wifi to the same access point. The resolution is 1280x720 and the framerate is 30 frames per second. The bitrate was limited to 2 Megabits per second.
