Cabinet Complete, Tank Drain Test
A project log for Solar Power Backyard Irrigation System
Practical Experimentation with Solar Power by watering flowers.
Pete HoffswellPete Hoffswell 06/14/2016 at 22:360 Comments
The cabinet is complete and simply resting on top of the barrel. I'm no cabinet maker, but it's functional.
We are due for a big storm tonight, so I thought I'd drain the barrel.
Not much sun right now - 0.0A charge from the cells. Battery voltage looks good, and we can see the pump is drawing 5.8 amps. (The display isn't burnt out, it's just how the camera captured it.)
The 50 gallon barrel was drained in 25 minutes to a sprinkler with 50' of hose. That's 2 Gallons per minute.
