HackADay Arduino Maker Crown
Rise For Your King
You will hence forth address me as your Grace.
Nine servos parade the acrylic molded crown, affixed in an arrayed scheme plotted by the Arduino MKR1000. A seated position is the first form, a calm but present light shone. When your Grace rises and depresses a button on his Pebble Classic, a second nobler form takes shape and a tweet is consigned notifying the peasants and Lords to bow their heads in reverence. Conflict arises, the crown must amend to suit an embattled King, the third form protective and fierce; another tweet is dispatched, protect your King!
Built entirely from refuse aside from the donated Arduino MKR1000
Notation - Much stood against I in this attempted episode that the artifactual quality is as consequence of surrender I shall avoid admitting to directly. My kingdom for a green screen and light box...and 3D printer and CNC and...
How To - ThingSpeak and Twitter
http://www.mathworks.com/help/thingspeak/thingtweet-app.html?requestedDomain=www.mathworks.com
  • 1 × Arduino MKR1000
  • 9 × Servo
  • 3 × TIP120 Discrete Semiconductors / Power Transistors and MOSFETs
  • 1 × 5V Regulator
  • 1 × RGB LED Strip
View all 10 components
  • ThingSpeak ThingTweet
    Vije Miller03/28/2016 at 16:40 0 comments
    Having cut the Maker Crown tweets from the video, to summarize, when you change the condition of the crown, it sends a tweet to the masses based on the state. The Arduino MKR1000 sends an update to a ThingSpeak channel where the state of the crown is stored as a numeral (0 through 4) and using ThingTweet addon, when the channel equals a certain condition (state 1 or 3) then it sends a tweet with a specific message.
  • Pebble JS App
    Vije Miller03/23/2016 at 09:37 0 comments
    // Maker Crown Peddle APP (Version 1.0) @TVMiller
    var UI = require('ui');
    var ajax = require('ajax');
    var Vector2 = require('vector2');
    // Create Window
    var main_window = new UI.Window();
    // Open Button and Display
    var txtOnLabel = new UI.Text({
        position: new Vector2(0, 15),
        size: new Vector2(144, 30),
        font: 'Gothic 28 Bold',
        text: 'RISE',
        textAlign: 'center',
        color: 'white'
    //this is going to be our off button
    var txtOffLabel = new UI.Text({
        position: new Vector2(0, 95),
        text: 'BATTLE',
        color: 'white'
    main_window.backgroundColor('black');
    main_window.add(txtOnLabel);
    main_window.add(txtOffLabel);
    main_window.show();
    // URL To MKR1000
    function Toggle(function_name){
      var URL = 'http://192.168.1.9/' + function_name;
      ajax(
          url: URL,
          method: 'post',
          type: 'json',
          data: { "args": function_name}
    // Rise
    main_window.on('click', 'up', function() {
      Toggle('R');
    // Battle
    main_window.on('click', 'down', function() {
      Toggle('B');
    // Seated
    main_window.on('click', 'select', function() {
      Toggle('S');
  • Arduino MKR1000 Sketch
    Vije Miller03/23/2016 at 08:48 0 comments
    // Maker Crown @TVMiller
    #include <Servo.h>
    #include <SPI.h>
    #include <WiFi101.h>
    // Servos
    Servo serone;
    Servo sertwo;
    Servo serthree;
    Servo serfour;
    Servo serfive;
    Servo sersix;
    Servo serseven;
    Servo sereight;
    Servo sernine;
    // Seat Positions
    int seatposone = 180; // Long
    int seatposoneA = 150;
    int seatpostwo = 10; // Short
    int seatpostwoA = 70;
    int seatposthree = 130; // Long
    int seatposthreeA = 85;
    int seatposfour = 0; // Short
    int seatposfourA = 45;
    int seatposfive = 1; // Long
    int seatposfiveA = 40;
    int seatpossix = 170; // Long
    int seatpossixA = 130;
    int seatposseven = 7; // Short
    int seatpossevenA = 35;
    int seatposeight = 170; // Long
    int seatposeightA = 125;
    int seatposnine = 7; // Short
    int seatposnineA = 45;
    // Seat Place Holders
    int posone = seatposone;
    int postwo = seatpostwo;
    int posthree = seatposthree;
    int posfour = seatposfour;
    int posfive = seatposfive;
    int possix = seatpossix;
    int posseven = seatposseven;
    int poseight = seatposeight;
    int posnine = seatposnine;
    // Delays
    int sitdelay = 20;
    int risedelay = 15;
    int battledelay = 5;
    // LED
    int red = 11;
    int green = 12;
    int blue = 10;
    // State
    int state = 0;
    // WiFi
    char ssid[] = "NETWORK";
    char pass[] = "PASSWORD";
    int keyIndex = 0;
    int status = WL_IDLE_STATUS;
    WiFiServer server(80);
    // ThingSpeak
    char thingSpeakAddress[] = "api.thingspeak.com";
    String APIKey = "APIKEY"; // API
    const int updateThingSpeakInterval = 100 * 1000; // Interval
    long lastConnectionTime = 0;
    boolean lastConnected = false;
    WiFiClient client;
    void setup() {
      Serial.begin(9600);
      // Servos Short
      sertwo.attach(2);
      serfour.attach(4);
      serseven.attach(7);
      sernine.attach(9);
      // Servos Long
      serone.attach(1);
      serthree.attach(3);
      serfive.attach(5);
      sersix.attach(6);
      sereight.attach(8);
      // Lights
      pinMode(red, OUTPUT);
      pinMode(green, OUTPUT);
      pinMode(blue, OUTPUT);
      serone.write(seatposone);
      sertwo.write(seatpostwoA);
      serthree.write(seatposthree);
      serfour.write(seatposfourA);
      serfive.write(seatposfive);
      sersix.write(seatpossix);
      serseven.write(seatpossevenA);
      sereight.write(seatposeight);
      sernine.write(seatposnineA);
      digitalWrite(red, HIGH);
      delay(500);
      digitalWrite(red, LOW);
      digitalWrite(green, HIGH);
      delay(500);
      digitalWrite(green, LOW);
      digitalWrite(blue, HIGH);
      delay(500);
      digitalWrite(blue, LOW);
      // WIFI Connection
      while ( status != WL_CONNECTED) {
        Serial.print("Connecting Network: ");
        Serial.println(ssid);
        status = WiFi.begin(ssid, pass);
        delay(5000);
      server.begin();
      printWifiStatus();
    void loop() {
      // Pebble WIFI Coms
      WiFiClient client = server.available();
      if (client) {
        String currentLine = "";
        while (client.connected()) {
          if (client.available()) {
            char c = client.read();
            Serial.write(c);
            if (c == '\n') {
              if (currentLine.length() == 0) {
                client.println("HTTP/1.1 200 OK");
                client.println("Content-type:text/html");
                break;
              else {
                currentLine = "";
            else if (c != '\r') {
              currentLine += c;
            if (currentLine.endsWith("GET /R")) {
              state = 1;
            if (currentLine.endsWith("GET /B")) {
              state = 3;
            if (currentLine.endsWith("GET /S")) {
              state = 0;
        client.stop();
      // Serial Input (Testing)
      if (Serial.available()) {
        char ser = Serial.read();
        switch (ser) {
          case '0':
            state = 0;
            break;
          case '1':
            state = 1;
            break;
          case '2':
            state = 3;
            break;
      // State Change
      if (state == 1) {
        rise();
        String kingpos = String(state, DEC);
        updateThingSpeak("field1=" + kingpos);
      else if (state == 2) {
      else if (state == 3) {
        battle();
      else if (state == 4) {
      else {
        seated();
        if (millis() - lastConnectionTime > updateThingSpeakInterval) {
    void printWifiStatus() {
      Serial.print("SSID: ");
      Serial.println(WiFi.SSID());
      IPAddress ip = WiFi.localIP();
      Serial.print("http://");
      Serial.println(ip);
     long rssi = WiFi.RSSI();
  • Fritz ...but Simmons floats my boat
    Vije Miller03/10/2016 at 10:35 0 comments
  • Skullen Form
    Vije Miller03/10/2016 at 10:33 0 comments
View all 5 project logs
davedarko wrote 11/04/2016 at 15:24 point
Great stuff!
Vije Miller wrote 11/05/2016 at 21:28 point
Fair warning, having a crown does not entitle you to act like a king and make demands of your subjects...I know that now. I...I know that now.
