Specifications
XYZ CNC MECHANICS
  • Cutting area: 900 mm x 900 mm
  • Z travel: 150 mm
  • Footprint: 1430 mm (W) x 1200mm (L) x 630 mm (H)
  • Speed: 1500 mm/min (max)
MOTION SYSTEM
  • XY motion system: Timing belt and pulley (T5 or HTD5M or HTD3M)3X Nema 23 stepper motors
  • Z motion system: M8 Threaded rod1X Nema 17 stepper motor
CNC CONTROL ELECTRONICS
RAMPS
  • OSHW: Yes
  • Voltage: 12-24 V
  • Driver: Driver-stick A4988 or DRV8825
  • Current: 2.5 A
  • Firmware: GRBL
  • Applications: Basic
ARDUINO + TOSLINK CNC
  • OSHW: Yes
  • Voltage: 12-36 V
  • Driver: PoStep-32, PoStep-256 or THB6600 based driver
  • Current: 5 A
  • Firmware: GRBL
  • Applications: Default
PLANET CNC + TOSLINK CNC
  • OSHW: No
  • Voltage: 12-48 V
  • Current: 5 A
  • Firmware: PLANET CNC
  • Applications: Pro
MACHINING
MILL
  • Material: Most materials
  • Tool: Spindle
  • Speed: 1000 mm/s (for 3mm birch wood with 3mm mill)
PLASMA
  • Material: Metal
  • Tool: Plasma torch
  • Speed: 1000 mm/s (for 3mm black steel)
  • Additionally required: Air compressor (30-100 l/min at 2-4 bar -effective 180 l/min)
LASER
  • Material: Wood and plastic
  • Tool: Diode or CO2 Laser
  • Speed: Depends on material
  • Additionally required: Air compressor, water cooling
