Text
A project log for CircuitPython Badge
A handheld running CircuitPython and cheap enough for a badge.
dehipudeʃhipu 04/02/2018 at 11:420 Comments
Whatever display I end up using, I'm going to need to display text on it. So I went to work on that. I drew a 6×8 font, which gives me 21 columns and 8 rows on the 128×64 display:
I went with bold characters, because I want good readability, and I used height of 8 pixels, because that's the display's page height, and it makes it super-easy to draw the characters. Since I only use the 128 ASCII characters (minus the 32 control characters, actually), I used the highest bit to reverse the text — that will be useful for cursors/menus.
I still need to figure out double-width and double-size characters somehow (if it's a badge, it'd better show your name in a font readable from afar).
