C214AA_XSBO_SCH.pdfSchematicsAdobe Portable Document Format - 44.80 kB - 03/31/2016 at 11:20 |
C214A_XSBO_PCB.pdfPCB DrawingAdobe Portable Document Format - 137.16 kB - 03/31/2016 at 11:20 |
LPC81X_UM10601.pdfLPC812 User ManualAdobe Portable Document Format - 1.71 MB - 03/31/2016 at 11:08 |
LPC81XM.pdfLPC812 Data SheetAdobe Portable Document Format - 734.18 kB - 03/31/2016 at 11:07 |
C214A_XSBO.GBR.ZIPGerber files - Compliant with Eurocircuits and PCBway pooling processes.Zip Archive - 290.02 kB - 03/31/2016 at 11:06 |
YASKarm_test_LPC812.hexThis hex file is a precompiled blinky test for the XSBO board.It can be flashed thanks to an LPClink board or with FlashMagic. This software produces a rather fast (2 Hz) heart beat on the board LED and toggles each available port 20 times per second. Keep in mind that P0_10 and P0_11 are open drain outputs. You will need pull-ups to see them toggle on your oscilloscope screen. hex - 12.68 kB - 03/22/2016 at 14:27 |
YASKarm_test_LPC812.cTest program source file. Uses my YasK kernel. Just ask me if you want the complete package in order to recompile the program.C Source File - 3.79 kB - 03/31/2016 at 11:09 |
