Testing the prototype 1 ¡FAIL!
A project log for xLiDAR
Affordable and open-source LiDAR based on 3x VL53L0X ranging sensor
jrodrigoJRodrigo 06/03/2018 at 19:242 Comments
When I tested the prototype, as I already expected, it was impossible to maintain a stable communication via I2C when the rotor turns around.
The positive part is that the power via "SD pins" was stable with some capacitors, maybe using a couple more of SD pins gets a more stable voltage.
Emil Novak wrote 05/12/2019 at 16:28 point
Great work! I would suggest optocoupling to transfer the ToF data with small microcontrollers (like 10f2xx or atTiny), only delivering power through the slip ring. Something similar can be found in the orange xiaomi lidars.
wNeves99 wrote 11/03/2018 at 06:48 point
Why I2C communication fails ?
