Where I'm at.
A project log for Trombino
The Trombino is a trombone like interface which produces both sound and OSC data. It is being created as a tool for teachers and musicians.
ipodlingiPodling 05/01/2014 at 16:580 Comments
So the Trombino is in the sort of advanced prototype stage at the moment. All the hardware has been settled on and works, I'm currently working on making sure the outputs are as useful as possible (for example currently the OSC data it outputs is in the format of mouth reading and note calculated from trombone like mappings, I'd also like to output the data without mappings and in MIDI form).
