Attiny flasher
Attiny series microcontroller flasher
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This small project I use to flash Attiny85 microcontroller using Arduino Pro Mini board (Chinese clone actually). Most of the work is done by Arduino team and can be found here https://www.arduino.cc/en/Tutorial/ArduinoISP
My pcb is adaptation for day-to-day use.
If i would do version 1.1 I would make outputs breadboard friendly (ground-power pair and 6 gpios). Also i would flip Attiny socket 90* - this way would be easier to get it in or out.
