Very brief review of ATmel's new ATtiny 102
A project log for Minimalist A-go-go
A project inside Attiny. I will not step out for larger one till I complete it.
kodera2tkodera2t 04/10/2016 at 09:203 Comments
Fortunately I got very recent ATmel MCU ATtiny102 and quickly tried to program RGB LED blinking through ATmel Studio. I found several differences from conventional 8-pin AVRs in every aspect.
(1) programming method is NOT SPI but TPI
So far, 8-pin AVR was programmed by SPI (MOSI/MISO/CLK/RESET..) but this new 102 accept only TPI, which is same as ATtiny10.
(2) Pin assign is completely different!!!
As shown in the above picture ATtiny102 (up) has 1-pin VCC and 8-pin GND. This is totally different from conventional pin assign (which was totally pin compatible in 8-pin AVR series, ATtiny 13 to 85). We need a bit care for initial prototyping test.
(3) New 102 has two output ports PORTA and PORTB
I guess, ATmel uses same chip for 102 and 104 (simply most of ports are not wired in 102) and as a result 102 has two ports. This means, little source modification is required from conventional 8-pin AVR to 102.
(4) Additional voltage reference (1.1 V, 2.2 V, 4.3 V) for A/D converter
Voltage reference can be selected by REFS1 and REFS0 in ADMUX. Some ATtiny has 1.1 and 2.56 V reference but they has some limitation, requiring external capacitor. But the case of 102/104, it is completely free of charge.
(5) USART and USARTSPI (functions exclusive) supported
Not bit-banged but serial and SPI (one of them) are supported..
As for programming, ATmel Studio has already supported ATtiny102/104 and we don't need to wait for something.
Actual operation can be found in the following movie...
qquuiinn wrote 07/26/2016 at 07:24 point
How did you get ahold of the attiny102? It's not in stock at every electronics distributor that i've checked.
kodera2t wrote 07/26/2016 at 22:19 point
Hello, as you can see the model number has a suffix "-ES" meaning "engineering sample".
qquuiinn wrote 07/26/2016 at 22:21 point
thanks
