Resistor-Latch-Logic, loading, capacitance... Two separate paths?
A project log for sdramThingZero - 133MS/s 32-bit Logic Analyzer
Add an old SDRAM DIMM to your SBC for a 133MS/s 32-bit Logic Analyzer, add ADCs for a Scope...
eric-hertzEric Hertz 11/02/2016 at 10:150 Comments
I've mentioned this a few times in past logs, using resistors to route data-flow where otherwise it would be "logical" to use logic (gates, buffers). Especially to interface with the *bus*. A few reasons: adding buffers requires the addition of another control-signal for each device connected to the bus, resistors are cheaper than buffers, and of course I'm attempting to use the SDRAM's inherent features wherever possible... Maybe not *great* reasons, probably not ideal in a *product*, but maybe easier in some cases for hobbiests, etc., and just another way of looking at things...
(Of course, the DQ-latches have an Output-Enable, which gets toggled as-appropriate).
So, a little bit of math might suggest that this would be quite difficult, especially when connecting *multiple* devices to the bus. The input-capacitances of all those devices (and the processor's bus, itself) add up...
E.G. at 133MHz, say, 3ns is a reasonable rise/fall time... And say the capacitance of the inputs is something like 50pF... T=RC... that'd be 60ohms for our resistors. Yeah, that'd be tough... lotsa milliamps when several DQ-latches are holding a "1" and the bus drives the latch-inputs to "0". Etc. Etc. (OTOH: In most of these cases, there's no reason to drive the outputs at the same time as there's data on the bus... hmmmmmm)
One big consideration is the fact that the bus is generally *not* going to be 133MHz.
(Pi's GPIO toggle rates allegedly max out at around 50MHz, and the step-wise process of controlling the bus is several steps between each read/write).
So, we might be able to bump those resistor-values up a bit without dramatically slowing *bus* transactions.
Here's some data from the Micron 64Mb SDRAM Datasheet:
But, this shizzle adds-up, right? Each DIMM may contain up to *16* chips (8 per side) all connected to the same command/address lines... That's 16*5=80pF! But, also, the Command/Address pins are directly-wired to DQ's, so that's 86.5pF, then the output of the DQ-latch...
And that's on the *non-bus* side of things... (is this going to affect free-running?)
Output-High and Output-Low voltages are spec'd at 4mA, too... (but not listed as a PC100 spec). so, hmm...
So, not sure... There may be some more in-depth pondering to do as we bump up this thing's speed...
This might be turning into two separate paths...
One that can be built with a minimum of parts, on a breadboard, etc... and maxes out at a low-speed (30MS/s, currently), depending on your available parts... That's still greatly-functional for many people's needs, especially for something that could be assembled in a weekend from parts-at-hand.
The other, to achieve 133MS/s, might require more and higher-quality parts; buffers (maybe latches?) in the feedback-path, buffers instead of resistors in the bus-interface and other locations, an additional 8-bit latch for the bus-buffers' output-enables... Probably a couple extra 8bit latches, as the "address-jumping" technique wouldn't then make sense to implement... And, of course, would need to be on a PCB.
At this point, the second path seems a long ways off, if at all. There's still a lot to be seen regarding just how much can be pushed outta solderless-breadboarding, etc.
