PCB Version 2
A project log for Single Layer Through Hole Arduino 328 & NRF24 PCB
Minimal, Long Range, Low Voltage, Long Life, with switchable RF Vcc
haydenhayden 03/14/2016 at 21:530 Comments
Here is Version 2, all IO pins are brought out for easy re-purposing, the vcc ripple cap as a spot (C2) and the reed switch spacing is wider.
