2xAA RF Limits
A project log for Single Layer Through Hole Arduino 328 & NRF24 PCB
Minimal, Long Range, Low Voltage, Long Life, with switchable RF Vcc
haydenhayden 04/09/2016 at 06:150 Comments
After using this in one of my other projects (wireless tank gauge) , ive come to find something i overlooked and did not notice in my initial use. While the 328p (1.8v-5.5v) will happily run off 2xAA (or AAA) batteries either Alkaline or NIMH the NRF24 is a little more fussy, and is rated for 3v3, apparently though it can handle 5v logic connections but the vcc must be 3v3. So as my 2xAA NIMH started to discharge it cut out at 2.6v, so its more suited to the upper charge states of 2 alkalines (2.6v-3v), or 3 nimh (2.8v-3.6v).
