A small 4017 based 10 step stepsequencer
Not a member? You should Sign Up.
Already have an account? Log In.
A stepsequencer roughly based on the Baby 10 schematics
The PCBs from Dangerous Prototypes dev Shop arrived. The look pretty good. I hope i did not make big mistakes and this works.
As soon as i got a board together i'll post another update.
Today i sat down to get the schematics and PCB routing to the first done step.
Pretty happy with the routing, but i think i still need to breadboard the circuit again - not really sure about the opamp buffer for the CV and the gate-in circuit.
View all 2 project logs
When there is a 4017, the project can't be too bad !
I plan on hacking a diode/transistor 4017 later this year. Your layout looks good :-)
youkito1991
MEGA DAS
Yes, delete it Cancel
You are about to report the project "c_rittmacher", please tell us the reason.
