Build - Step 2
A project log for 18 DOF High-Flotation Hexapod Robot
Six legs, 18 servos, with optional high-flotation mode. My first project that combined robotics and 3D printing.
kendoken.do 09/03/2017 at 00:380 Comments
2. Assemble the 'hip' sections
Two identical hip sections are placed together 90 degrees from each other.
Attach them through the center hole with a 4mm x 1/2 inch-ish machine screw and nut.
