4 x 4 x 4 RGB LED cube Rainbowduino
To better learn soldering. Building a kit set ordered online.
0 followers
I've got this kit with the pre-cut Acrylic housing. But before i can complete this project a little modification. 2 more openings need to be made. On the underside of the PCB-board i can connect the USB cable and 9V power. I want to be able to connect those with the housing over the cube for easy access.
More info soon
gwatson1025 wrote 06/06/2017 at 21:44 point
I assume this is a homemade project and not a kit ? I think it would be pretty cool to try one if you want to share the Instrutioanl details
