Soldering done !
A project log for Modular Potato Powered Robot
Powering LEDs or clocks with potatoes is too simple for you ? Let's build a modular robot powered by a single potato !
alexandre-le-gallAlexandre LE GALL 07/05/2018 at 18:450 Comments
I just finished soldering the boards.
I made some mistakes but it was easily repaired.
I have not yet test everything, but the buck boost converter (energy harvesting module) and the quad comparator (motor driver module) is working properly.
Tomorrow, I will try to flash the microcontroller, and test the the H-Bridge ICs...
