Moving Forward
A project log for Little Friend
This companion robot, 9000 farads of super capacitance, spends less than eight minutes feeding--then 75 minutes or more she can be a buddy.
mike-rigsbyMike Rigsby 04/03/2016 at 00:070 Comments
Looking to the time frame and materials required, here's my current thinking.
April, 2016
Create ability to find charging station. I will use the Pololu IR Beacon Transceiver Pair and program the bot's Arduino to utilize the information received from the IR beacon. If this fails, my backup system will be to use the Pixy camera (I've done this on another project, but power consumption, lighting and expense put it in the number two position).
May, 2016
Build the charging station and pickup points for the bot. I'm thinking rollers and rails from an O gauge train may work for this.
June, 2016
Add people sensing and "excited to see you" routines. A PIR sensor will be used for human (or animal) detection. This is more tricky than I first thought, since the bot must be still for the "motion detector" to detect motion that is not caused by the bot.
July, 2016
Add stair detection. Some sort of IR detectors will be used for this.
August, 2016
Build a people friendly body, including eyes with servo controlled eyelids.
September, 2016
Build Taco, the people friendly "shell" for the charging station. Taco will have servo controlled eyes that "blink" when Mato passes by.
