We construct and design the levers and holders for a Five Link Mechanism
The most difficult is design of a hole for servo shaft. We made it by drilling of some amount of 0.8 mm diameter holes. We use servo s9g. The shaft of s9g is 20-tooth gearwheel. We drill 21 hole of diameter 0.8 mm, the radius of the guide circle is 1.87 mm. Here You can see
