Modeled the ring gears. Center and right have 23 teeth, left has 22 teeth.
Image discs fit inside the ring against the lip, and another collar presses in to lock it in place.
They will rotate in the housing on the round hub.
A project log for Interdimensional Portal Gun
A 3D printed portal gun, which projects animated portals.
