Printed it out. The handle fits the body perfectly and hides the seam pretty well. The V notch I put in the ends lines everything up for you.
The bottom looks great too. The hexagons filled in a bit though. I may change them back to cylinders so I can drill them out after.
The handle is also plenty strong, and so should withstand some abuse.
But, I snapped off both fan mounts and one servo mount in about 3 hours of handling it.
I printed this at 90mm/sec, 2 walls, and 50% infill so it's kinda my fault. They may have survived at 4 walls, but I think I'm going to move the fan up slightly and go back to using screws to mount it.
The servo studs have been modified and are now 10mm instead of 7mm. That should do it.
