stuff to build
A project log for Ion blaster
A gun to charge stuff around
deepsoicDeepSOIC 03/15/2016 at 11:570 Comments
So, a quick glance at what needs to be made for this project.
I plan to make the system modular.
1. a powerful 3d-printed fan-blower (I need to visit RC store to get a good efficient motor for this)
2. ionizer attachment.
Next, try it out with stationary high-voltage power supply, that I have already. That will give me the idea if it is worth to continue the project, and the target specs of high voltage for ionizer.
3. make a compact battery-powered high-voltage supply for ionizer. The main evil plan here is to use backlight inverter module salvaged from an LCD monitor of a laptop.
4. design and 3d-print the case to enclose the whole unit.
