Excerpts from the Master Thesis
A project log for Visual Marker Tracking for Robotics
Easily record and analyze the moves of robots, indivitual joints, ...
danielDaniel 03/14/2016 at 21:170 Comments
This is where the idea originated:
The aim was to track the expansion of a soft pneumatic actuator to be used in the leg of a jumping robot. Detailed analysis of the accelerating motion was obtained with a high-speed camera.
It was easy to perform lots of test runs with different parameters (air pressure, payload weight) thanks to the automated motion analysis.
Using multiple trackers in one scene.
The jumping robot jumping :-)
