Inital Testing
A project log for IOT - ESP8266 Dual Relay Module Controller Shield
Intended for a ESP8266-01 module Using NodeMCU Firmware To control my Solar PV setup DC disconnects remotely
Charles LakinsCharles Lakins 04/05/2016 at 21:560 Comments
Testing seems to be ok, 5v and 3.3v are spot on, but its not connectiing to the AP but will with just voltage supplied & reset works as intended
I think the code needs to set the gpio high so it doesn't enter flash mode on startup besides that so far so good
