IOT - ESP8266 Dual Relay Module Controller Shield
Back to overview
Intended for a ESP8266-01 module Using NodeMCU Firmware To control my Solar PV setup DC disconnects remotely
Vlad wrote 11/10/2021 at 20:41 point
Hi, what is the reason to use both SSR and mechanical relays? You can connect your esp relay shield directly to SSR, just remove relays from the scheme, and connect green and gray wires to (-) of SSR, and red one keep connected to (+)
