First Assembly
A project log for IOT - ESP8266 Dual Relay Module Controller Shield
Intended for a ESP8266-01 module Using NodeMCU Firmware To control my Solar PV setup DC disconnects remotely
charles-lakinsCharles Lakins 04/05/2016 at 18:231 Comment
First Board Assembled - Testing to follow
Charles Lakins wrote 04/05/2016 at 18:58 point
regulator and voltages - check out fine,
I think the code needs a revision to prevent flash mode from enabling on boot
besides that everything checks out
