Code or resistor value discrepancy
A project log for IOT - ESP8266 Dual Relay Module Controller Shield
Intended for a ESP8266-01 module Using NodeMCU Firmware To control my Solar PV setup DC disconnects remotely
charles-lakinsCharles Lakins 04/05/2016 at 23:560 Comments
Theres a Code or resistor value discrepancy for the GPIO0 for reset
when I remove R3 (1K) to disconnect the transistor for relay output the board boots and connects to the AP Correctly ,so its either the code or a resistor value
Considering adding a diode for output only on the R3 Trace so it doesnt see anything from the transistor side
