First Print
A project log for 3D Printable Stroke Victim Writing Utensils
3D printable writing utensils for stroke patients suffering from aphasia who cannot hold normal pens or pencils
neil-meansNeil means 03/28/2016 at 08:200 Comments
Some stroke patients can hold onto a ball, but not a regular sized pen. So the solution is to put a ball onto a pen. The large surface area of the ball allows for weak fingers to hold onto the pen. I used tinkercad to create a 50mm sphere with a 9mm pen hole that is offset from the sphere center. There are 2 set screw holes at 3mm each to secure the pen.
Printing on a modified XYZ DaVinci 3D printer...
Print is almost complete.
Tap for set screws to secure pen.
Ball with pen
