Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Events Hackerspaces Profiles Hackaday.com Tindie Marketplace Remoticon
Sign up Log in
WINXI - arduino ZERO Pro M0 stick AtSamD21E18
this board have unique compact design and is easy to assembly
+RGB led
+User button
bobriciusbobricius
Following Follow project
Liked Like project
Become a Hackaday.io member
Not a member? You should Sign Up.
Already have an account? Log In.
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
10.3k views
5 comments
97 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 0
  • Logs 7
    • View all
  • Instructions 0
  • Discussion 5
  • The 2016 Hackaday Prize
View Gallery
10.3k
5
97
92
Team (1)
  • bobriciusbobricius
Join this project's team
  • My store
ongoing project
arduino Zero m0 Atsamd21E18 SAMD21 ATSAMD21 2017HackadayPrize circuitpython
Related lists
SMART ARM-based Projects
AtmelĀ®|SMART MCUs combine powerful 32-bit ARM cores with industry-leading low-power technology and intelligent peripherals.
Projects using OSHpark boards
projects using the purple PCBs
2016 THP: Atmel Parts
Hackaday Prize Entries using Atmel parts
Awesome Projects on Tindie
Hackaday.io projects you can buy in the Tindie maker marketplace
2017 THP: Digi-Key Parts
Hackaday Prize Entries using Digi-Key parts
Browse related lists
This project is submitted for
  • Hackaday.com Tip Line
  • Get Started: Design Your Concept
This project was created on 03/14/2016 and last updated 10 months ago.
Description
Based on newest arduino zero board with powerfull mcu.
Native 3.3V, many sensors, modules and SD cards are working on this voltage level
I want small board :
=> fun without shields
=> I2C header
=> micro sd reader
= WINXI (because predecessor have small wings)
-user button
-power led
-optionall micro SD Card reader (not supported in arduino IDE now)
-RGB LED
-touch button pad (on bottom of board)
-I2C header
-Jtag header
-metalic Usb-A support
-in next version vertical Usb for usb host
-minimum components
-I think really nice shape :)
-Atsamd21E18 (TQFP32 > same size as atmega328), more soldering fiendly than Atsamd21G18 (LQFP48)
-no EDBG chip, programming via native usb only
-256kb flash
-Smart pinout !!!! Direct IIC/ TWI sensors most used combination vcc/gnd/scl/sda
Powered from usb, it is great, you can use any your phone charger, powerbank etc...
No jtag programmer required, board have integrated USB bootloader
Files
samd21SLIM-sd-longer.sch
sch - 373.13 kB - 03/23/2016 at 22:28
See BOM
Download
samd21SLIM-sd-longer.brd
brd - 115.82 kB - 03/23/2016 at 22:28
Download
Project Logs
Collapse logs
  • TQFP version
    bobricius • 11/15/2016 at 22:21 • 0 comments
  • RTM both QFN and TQFP variants :-)
    bobricius • 11/15/2016 at 22:14 • 0 comments
  • Winxi & micropython
    bobricius • 10/13/2016 at 22:08 • 0 comments
    Adafruit intensive working on port micropython to SamD21.
    I have tested it and it is amazing ! Everything seems working
    REPL, Mass storage ....unfortunately I have no idea about Pyhon, but It is time to start learning.
    https://github.com/adafruit/micropython
    And what is best????
    Cool you can leave zero bootloader, just upload binary and winxi is micropython board, If you want go
    back to arduino ...just press twice reset button and use arduino IDE .... great ...
  • I need HELP
    bobricius • 06/24/2016 at 11:10 • 0 comments
    Can anybody help how to modify / create SD card library to work with winxi pinout? And I need Audio library work. I can send you board for testing.
  • Boards received
    bobricius • 04/15/2016 at 12:19 • 0 comments
    Boards received, assembled an working :)
  • v1.5 boards ordered
    bobricius • 03/23/2016 at 23:05 • 0 comments
    + reset button
    + PTC fuse
    + 3 mm :(
    - Touch pad
  • new v2. boards
    bobricius • 03/23/2016 at 22:33 • 0 comments
    Features for v 2:
    - QFN package
    - Reset button
    - PTC Fuse for USB
    - vertical micro USB
    - vertical USB host
    - solder jumper for Power LED
    - IIC pull up resistor
    - hand routed
View all 7 project logs
Log In/Sign up to comment
Sign up with Github
OR
Domen wrote 06/01/2016 at 08:55 • point
How much would parts for such a board cost @ 1000 units?
You have done a great job on this project!
Manuel Domke wrote 05/22/2016 at 09:53 • point
Very nice project. I'm currently starting to build one of these. I already have AtSamD21E18 in QFN32-package. Can you share those version 2 PCBs with us please?
Jan Szumiec wrote 03/23/2016 at 18:13 • point
This is lovely. Where can I get a PCB?
bobricius wrote 03/23/2016 at 22:29 • point
uploaded in files
Jonathan Beri wrote 03/17/2016 at 01:24 • point
I really like dev kits with usb directly on the board. This would make a great EDC!
atsamd11c14 Arduino zero compatible ARM M0 compact usb stick
Project Owner Contributor
DiXi - arduino sam D11 usb stick
bobriciusbobricius
The 2018 Hackaday Prize
Powerful, Arduino compatible prototyping board having USB port which makes it ideal for makers.
An ultimate mini version of Arduino
Patel DarshilPatel Darshil
This is the ONLY protoboard that you'll need !!!
ZuC Protoboard
arief ibrahim adhaarief ibrahim adha
An on-board Arduino with a mini-PCIe form factor
PCIeDuino
Gergely ImrehGergely Imreh
Going up?
© 2021 Hackaday
Yes, delete it Cancel
You are about to report the project "WINXI - arduino ZERO Pro M0 stick AtSamD21E18", please tell us the reason.
Send message
Remove Member
