TQFP version
11/15/2016 at 22:21 • 0 comments -
RTM both QFN and TQFP variants :-)
11/15/2016 at 22:14 • 0 comments -
Winxi & micropython
10/13/2016 at 22:08 • 0 commentsAdafruit intensive working on port micropython to SamD21.
I have tested it and it is amazing ! Everything seems working
REPL, Mass storage ....unfortunately I have no idea about Pyhon, but It is time to start learning.https://github.com/adafruit/micropython
And what is best????
Cool you can leave zero bootloader, just upload binary and winxi is micropython board, If you want go
back to arduino ...just press twice reset button and use arduino IDE .... great ...
I need HELP
06/24/2016 at 11:10 • 0 commentsCan anybody help how to modify / create SD card library to work with winxi pinout? And I need Audio library work. I can send you board for testing.
Boards received
04/15/2016 at 12:19 • 0 commentsBoards received, assembled an working :)
v1.5 boards ordered
03/23/2016 at 23:05 • 0 comments+ reset button
+ PTC fuse
+ 3 mm :(
- Touch pad
new v2. boards
03/23/2016 at 22:33 • 0 commentsFeatures for v 2:
- QFN package
- Reset button
- PTC Fuse for USB
- vertical micro USB
- vertical USB host
- solder jumper for Power LED
- IIC pull up resistor
- hand routed
