Language center
A project log for Humanoid robot named Murphy
Created to explore new ways of artificial intelligence
m-bindhammerM. Bindhammer 04/18/2016 at 18:550 Comments
Language areas of the human brain are located at the Angular Gyrus, Supramarginal Gyrus, Broca's area, Wernicke's area and the Primary Auditory Cortex.
Murphy's language center consists of a 2 W, 8 Ω miniature loudspeaker, an EMIC-2 text-to-speech module and a TPA2005D1 breakout board. Both PCB's do not have mounting holes, so I designed a carrier board:
Populated and under testing (10k potentiometer for volume control still not added):
Wiring diagram:
Important note: The EMIC-2 does not work properly with Arduino hardware serial. Use the SoftwareSerial Library instead.
Demonstration video below. Do you know which movies contain these quotes?
