Attempting to transmit code to control switches
A project log for Automation - 434MHz Arlec power switches
Hooking arlec RC power switches up to modern home automation systems
shinyShiny 03/15/2016 at 20:470 Comments
From the remote (works)
Decimal: 1786416795 (32Bit) Binary: 01101010011110101000111010011011 Tri-State: not applicable PulseLength: 262 microseconds Protocol: 1
Raw data: 8148,744,252,740,264,732,268,244,744,744,256,256,712,2988,20,756,244,740,272,732,256,748,248,288,44,1424,20,264,728,748,252,260,736,740,260,256,740,260,736,260,736,744,252,748,248,744,252,260,740,736,264,248,752,248,748,732,264,732,264,256,736,744,252,744,244,
From my arduino (doesn't work)
Decimal: 1786416795 (32Bit) Binary: 01101010011110101000111010011011 Tri-State: not applicable PulseLength: 263 microseconds Protocol: 1
Raw data: 8172,296,776,808,272,800,268,284,784,812,260,288,788,800,272,276,792,284,792,804,268,804,264,812,260,812,264,272,796,808,264,276,796,808,264,276,796,280,792,280,792,804,268,800,272,800,272,276,796,804,268,272,796,276,796,808,264,808,264,276,796,808,264,808,264,
