voltage divider...
A project log for Automation - 434MHz Arlec power switches
Hooking arlec RC power switches up to modern home automation systems
shinyShiny 04/25/2016 at 23:510 Comments
The switches cause the micro to send the signal, when they are pulled low.
I've hooked up a voltage divider on each GPIO digital pin on the arduino, so about 2.5V appears at the switch, instead of 5.
