New board
A project log for 4 digit charlieplexed segment display
ultra thin custom display ... only 6 gpio for 30 leds
bobriciusbobricius 07/14/2016 at 22:113 Comments
de∫hipu wrote 08/04/2016 at 09:10 point
I wounder if you could put the resistors on the other side, and also have holes for them, so that the back would be completely smooth.
Alex wrote 08/04/2016 at 08:53 point
Nice Packaging. Do you have a picture of this display in action? And one more question: Which PCB thickness did you used here? 0.6mm?
K.C. Lee wrote 07/14/2016 at 23:42 point
You could use a SMT pad for the top diffuser PCB instead of the through hole pads.  It is a bit more tricky for alignment, but the pcb can still be stacked and soldered together.
