Skateboard Speedometer by inventED
Bluetooth Skateboard Speedometer in a 3D-printed housing, communicating with an Android App made with Processing.
In this project i will realize to develop a complete product:
-Speedometer(based on Arduino with bluetooth module, hall sensor and LiPo battery)
-3D-Printed Housing(this Speedomerter should to work for streetskating, grinding & sliding)
-Arduino program for Speedometer
-Android App made with Processing
First impression;):
https://youtu.be/CC7X-Vp8hto
When the wheel is turning a bar magnet(drilled a hole and put it in the wheel) is passing hall sensor and a revolution can be recognized. That´s the way it works. Sending the data to smartphone via bluetoothHC-05(will change to 4.0 BLE).
In the app you can read the speed(kmh), distance(m) and wheel revolutions. My app is still missing max speed, average speed.......
For now my app got no features exept
showing kmh, distance and wheel revolutions.
I would like to add:
-Battery indicator(battery status of the Speedometer)
-funktion to reset revolutions and distance-> in the app
-save revolutions and distance in eeprom of atmega 328
-max speed, average speed......usual speedometer features
Further i want to imrpove the Speedometer:
-using Bluetooth 4.0 BLE (already ordered some CC2541 modules)
-improving battery efficiency with another hall sensor (u18 already ordered)
-when all hardware is finally set i would like to make an layout and my own circuit board
Thanks to Till & Consti for the help!
Sk8tachov0_2.zip
Processing Android Mode sketch with Folder.
Zip Archive - 1.33 MB - 04/18/2016 at 22:44
Download
Sk8Tacho_1.5.ino
Arduino sketch for the Speedometer.
ino - 883.00 bytes - 04/18/2016 at 22:42
Download
Portable Network Graphics (PNG) - 1.61 MB - 03/16/2016 at 01:07
Preview
Download
  • 1 × Arduino Pro Mini 8mhz 3.3v version
  • 1 × Bluetooth Module HC-05
  • 1 × LiPo Battery 150mAh 3,7v
  • 1 × Hall Sensor
  • 1 × Android Smartphone
  • Update
    edbraun01/30/2017 at 21:50 0 comments
    Hi,
    long time ago since my last update. I made a cover for my Shapeoko so that i can mill with high RMP without getting deaf. I learned how to create PCBs Layouts with Target3001, learned how to mill two sided PCBs with my Shapeoko, and made myself a Internet Site:
    http://www.invented.tech.blog/
    Now i'm done with my first 2 prototype PCBs. Maybe i have to make one more smaller layout, so it will fit nicely under the truck. Next step is a smaller PCB and a fitting housing. Then i need some more focus on my Android app. Have a look on my new PCBs:
  • "Klick-slide mechanism"
    edbraun04/18/2016 at 22:20 0 comments
    Hello,
    i made some improvements on my housing.
    Neodym magnets do not work because only the rod through the truck is magnetic, not the truck itself. Shame on me... so i came back to my other 2 ideas: screwing or gluing. But i don´t like the idea to leave the Speedometer all the time at the truck. So i decided to make a "klick-slide mechanism", so i can fix a holder with glue or a screw constantly at the truck. This was much work for me but i think it works realy good for now, hopefully strong enough for street skating. I did a acetone vapor bath with the 3D-Printed housing to make it stronger. Also made a video that shows the click mechanism. Will get this week some silikone, i think this will be a good option to glue the holder on the truck. I´m looking forward to test it with some tricks;-).
    Here are some pictures:
  • Housing on Thingiverse
    edbraun03/26/2016 at 14:35 0 comments
    Hey Guys,
    I put the housing files on Thingiverse. The housing is still under improvement and not realy useable.
    http://www.thingiverse.com/thing:1444323
    Thanks for interest on my projekt!
  • New Housing....
    edbraun03/20/2016 at 22:19 0 comments
    Hi,
    my new housing is ready. There are still some things to improve. I need an liitle nice on/off switch..... and a good connector instead of the pins. But first i got something else to figure out:
    How to keep the housing on the truck?
    I got three things i wanna try:
    1. using a big magnet in the housing to keep it on the truck
    2. double sided adhesive tape
    3. or a screw through the truck
    If anybody got another idea please let me know.
    Some pictures of my new 3d-printed housing:
    Bye! Have a good week!
View all 4 project logs
Neon22 wrote 06/19/2016 at 02:57 point
so whatt are you finding for the speed vs wheel diameter ?
Is it mapping to expected speeds, and distances based on circumference (PI * D).
of course the magnet is not at the outside edge so you have modified calculation...
Chris wrote 03/23/2016 at 23:14 point
Hi Ed, that speedometer you made for your board is real cool, have you tried it on a longboard? Or maybe try using longer trucks, you will have more space on the truck axle ito attach it. I ride a sector 9 longboard, with independent trucks that are next to longest trucks on the market. Maybe if you ran some zip ties around it, that might help to hold it on too
edbraun wrote 03/26/2016 at 14:48 point
Hey Chris thank you for your interest! I´m also riding independent trucks....but about 8inch. Back in the days i used to skate a lot of street....so i decided to make a solution which you can also use on a street skateboard with no limitation in grinding and sliding. In the moment i´m not at this point;). But the housing is already out of the way for grinds and slides. But how to fasten the housing on the truck is now my chalenge.
Using zip ties doesn´t work due to the shape of the hangar....zip ties will always slide to the wheel.
As you can see i used in my video insulating tape to keep it on the truck, this worked realy good but is no solution.
Maybe you can give me the measurements of your trucks and i can made another version aswell?
