close-circle
Idle Waste Alarm
Start your car THEN use your phone? Cease waste for a "LOL" with this re-conditioning tool. Pre-MKR1000 version.
A pre-WIFI Arduino MKR1000 cloud data recording version.
A growing contradiction of the masses is concern for the environment while simultaneously being wasteful slobs. The belief that self matters veiled by an internet fog often perverts attention to atmospheric abuse and trivial consumption of resources that a human just 40 years ago would have milked for every drop.
One very aggravating all too frequent observation is the running-automobile-phone-user. A text or status update in your running parked car I would equate to treason. In reality, sheep and shepherd are the only true biological conditions of our species; so here is a first version shock blanket for your filthy habit.
Ideally, such a device may be wired and concealed, programmed by manufacturer (eh?!) or self prescribed to treat such a disability. In this particular model, an accelerometer affixed to an Arduino Nano reads variations of movement, accumulating time idling to a warning after 2 minutes, as to navigate around average traffic light pauses.
A pending model utilizing the Arduino MKR1000 stores the motion to idle ratio and warnings, then when near a known network, transmits the stored data to ThingSpeak for collection and analysis.
Stop being who you are now because is it not better in spite of your comforts.
RESEARCH
Idle Fuel Consumption
0.6L/HR per Liter Engine Displacement
Sample
Toyota Camry 2.5L 4CYL (#1 U.S. Mid-sized Sedan)
2.5 x 0.6 = 1.5 ÷ 60 = 0.025L/M
Idle Pollution
9 gram(s) of toxins (ex. CO2) per 1 minute
Walmart Locations
United States 4,540
International 6,301
Sam's Club 647
Calculation (Muted Prognosis)
10 Idle Texters per Day per U.S. Walmart Parking Lot
10 x 4,540 = 45,400
45,400 x 9 = 408,600 Grams (901 Pounds) of Pollutants per Minute
408,600 x 5 Minutes Texting = 2,043,000 Grams (4,504 Pounds)
408,600 x 20 Minutes = 8,172,000 Grams (18,016 Pounds)
45,400 x 0.025 = 1,135 Liters (299.8 Gallons) per Minute
1,135 x 5 Minutes Texting = 5,675 Liters (1,499 Gallons)
1,135 x 20 Minutes = 22,700 Liters (5,997 Gallons)
Reference(s)
http://tvmiller.com/index.php?entry=entry150528-203005
  • 1 × Arduino Nano
  • 1 × GY-521 MPU-6050 3 Axis Gyro Accelerometer
  • 1 × PIezo
  • 5 × 220 Resistor
  • 5 × LED Fiber Optics / Emitters
View all 6 components
  • Arduino and Resistor Tip
    VijeMiller03/17/2016 at 23:48 0 comments
    There are places on the net of inters that will attest that it is possible to place a resistor on the negative pole to GND
    DO NOT DO THIS WITH ARDUINOS
    Perhaps in a single simplified circuit you may get away with a resistor slowing current to the LED but an Arduino is not such a simple circuit. I could go in to pull ups and amps and current and more that I would need an electrical engineer to patter on about but allow me to give you a keep it simple stupid piece of advice;
    If using a microcontroller, the resistor goes from VCC to LED
  • Arduino Nude Sketch
    VijeMiller03/16/2016 at 19:47 0 comments
    // Idle Waste Alarm
    // Pre MKR1000 Version
    // Version 1.0 @TVMiller
    // MPU-6050 Sketch JohnChi
    #include<Wire.h>
    // I2C address of the MPU-6050
    const int MPU_addr = 0x68;
    int16_t AcY;
    // Sensitivity
    int high = 2700;
    int low = -2700;
    int set = 0;
    int dif = 0;
    // State
    int state = 1;
    // Time Variables
    long echo = 0;
    int dly = 100;
    // 120 seconds
    // Avg red light Wait 90 seconds
    long sepone = 22500;
    long septwo = 45000;
    long septhree = 67500;
    long sepfour = 90000;
    // LEDs and Piezo
    // Green
    int one = 3;
    int two = 4;
    int three = 5;
    // Yellow
    int four = 6;
    // Red and Piezo
    int five = 7;
    void setup() {
      Wire.begin();
      Wire.beginTransmission(MPU_addr);
      Wire.write(0x6B);
      Wire.write(0);
      Wire.endTransmission(true);
      Serial.begin(9600);
      pinMode(one, OUTPUT);
      pinMode(two, OUTPUT);
      pinMode(three, OUTPUT);
      pinMode(four, OUTPUT);
      pinMode(five, OUTPUT);
      digitalWrite(one, HIGH);
      digitalWrite(two, LOW);
      digitalWrite(three, LOW);
      digitalWrite(four, LOW);
      digitalWrite(five, LOW);
    void loop() {
      // GY-52 Communication
      Wire.write(0x3B);
      Wire.endTransmission(false);
      Wire.requestFrom(MPU_addr, 14, true);
      // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
      AcY = Wire.read() << 8 | Wire.read();
      // Variance From Last Position
      dif = AcY - set;
      // Testing
      Serial.print("YAxi  ");
      Serial.print(AcY);
      Serial.print("   Difr   ");
      Serial.print(dif);
      Serial.print("   Mils   ");
      Serial.println(echo);
      // IF Motion Reset Minimums
      if (dif > high || dif < low) {
        state = 1;
        echo = 0;
      else {
        if (state == 1) {
          if (echo >= sepone) {
            digitalWrite(two, HIGH);
            state = 2;
        else if (state == 2) {
          if (echo >= septwo) {
            digitalWrite(three, HIGH);
            state = 3;
        else if (state == 3) {
          if (echo >= septhree) {
            digitalWrite(four, HIGH);
            state = 4;
        else if (state == 4) {
          if (echo >= sepfour) {
            digitalWrite(five, HIGH);
      // Reset Last Position
      set = AcY;
      // 1/10 Second
      echo = echo + dly;
      delay(dly);
View all 2 project logs
