turingPi
A turingmashine simulator using a pi
0 followers
A turing mashine emulater using a pi to be programmd and an led rgb-strip as a work belt
  • 1 × ws281 strip Switches and Relays / Electromechanical Relays
  • 1 × pwersupply
  • 1 × Arduino compatible device with USB (or usb/tty)
  • 1 × cables, solder, switches ...
  • 1 × 1 k resistor (optional)
  • So, that did not work
    franz06/21/2016 at 08:51 0 comments
    So that does not work any more (i assume the Linux kernel was changed in some respect). That's why i chose the boring way of using an arduino, which has the advantage, that it now can be run from any Linux computer, although the raspberry pi can still be used in longterm installations.
  • installing the pi
    franz03/18/2016 at 16:41 0 comments
    #install the pi, then install the necessary software
    git clone https://github.com/jgarff/rpi_ws281x.git
    cd rpi_ws281x/
    vi main.c
    # //modify to sute your setup (size)
    scons
    sudo scons
    sudo ./test
    python3 setup.py build
    sudo apt install swig
    sudo apt install python3-dev
    sudo python3 setup.py install
    sudo python3 examples/lowlevel.py
View all 2 project logs
  • 1
    Step 1
    git clone https://gitlab.com/franzt1/jrgbtmp.git
    cd jrgbtmp/
    sudo apt-get install arduino openjdk-8-jre
  • 2
    Step 2
    connect the Arduino. install the sketch from the Git repository onto the arduino. connect the rgb band to pin 7 and the powersupply. You are now connected. Try the console manager in arduino, set the speed to 4900 baud and send the string "rgbx". It should now have a red, a green and a blue glowing led. everything is set up
  • 3
    Step 3
    cd src
    run the software. Although there might be a compiled version included recompile it with javac -sourcedirectory ../../....... ///
    and execute with java com.asdf....Main > /dev/ttyUsb
    Now the gui can be used to create turingmashines and run them.
View all 3 instructions
franz wrote 06/21/2016 at 08:54 point
it appers to not work annymore with new cernels, i might look into it
franz wrote 03/19/2016 at 14:44 point
well that's somewhat true
however the raspberry pi can do pwm, due to hardware features, and i found a softwoare (no linked in), that uses direct memory aces (dma) to magically toggle the pin without the ALU (the part of the CPU, that does most of the calculation and program execution work) involved.
I can't understand how it works (it writes directly to memory and has to run as root as a consequence), but it works well. what more could I wish for.
I am creating some circuit information coming up.
tinkerzone wrote 03/19/2016 at 02:16 point
Hi,
I thought that ws2812 strips couldn't be controlled by Pis as they can't supply a 400khz clock signal to keep them in sync? I thought they were only control able by non-os machines.
