So, that did not work
06/21/2016 at 08:51 • 0 commentsSo that does not work any more (i assume the Linux kernel was changed in some respect). That's why i chose the boring way of using an arduino, which has the advantage, that it now can be run from any Linux computer, although the raspberry pi can still be used in longterm installations.
installing the pi
03/18/2016 at 16:41 • 0 comments#install the pi, then install the necessary software
git clone https://github.com/jgarff/rpi_ws281x.git
cd rpi_ws281x/
vi main.c
# //modify to sute your setup (size)
scons
sudo scons
sudo ./test
python3 setup.py build
sudo apt install swig
sudo apt install python3-dev
sudo python3 setup.py install
sudo python3 examples/lowlevel.py
