1500F(800C) 1M K temperature probe
A project log for Engine Monitor
Real time graphic readout of critical engine performance parameters.
jan-zumwaltJan Zumwalt 03/31/2016 at 09:500 Comments
Aliexpress has $2-3 K Type Nylon Braided 800C 6mm Screw Thermocouple Temperature Sensor 1M 3.3Ft. The other option was 2M ohm, but the selection was poor.
Application:
4 CHT, 4 EGT
http://www.aliexpress.com/item/Hot-Sale-High-Quality-Stainless-Steel-High-Temperature-0-To-800-Degree-Thermocouple-K-Type-1000mm/32631426082.html?spm=2114.01010208.3.81.BgLA6r&ws_ab_test=searchweb201556_0,searchweb201602_1_10036_10035_301_10034_507_10032_10020_10017_10005_10006_10021_10022_401_10018_10019,searchweb201603_9&btsid=eeb69e66-6739-49d5-9b5c-14a00a8f58ad
